[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Mon Nov 27 18:00:53 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 - Fix memory leaks in the ODBC provider (merged from branch)
Modified
File: trunk/Utilities/Common/Src/FdoCommonConnPropDictionary.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/FdoCommonConnPropDictionary.cpp?view=diff&rev=542&p1=trunk/Utilities/Common/Src/FdoCommonConnPropDictionary.cpp&r1=541&p2=trunk/Utilities/Common/Src/FdoCommonConnPropDictionary.cpp&r2=542
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp?view=diff&rev=542&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r1=541&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r2=542
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp?view=diff&rev=542&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp&r1=541&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp&r2=542
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
