[fdo][FDO291][Modified] Fixed: Fail to create MySQL data store when MySql provider i...
    Romica Dascalescu
    romica.dascalescu at autodesk.com
    Mon Nov 27 18:21:13 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO291
Type:
Defect
Artifact ID:
FDO291 (Fixed: Fail to create MySQL data store when MySql provider is installed under a folder with double byte characters)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO291 Fixed: Fail to create MySQL data store when MySql provider is installed under a folder with double byte characters (merged from branch)
Modified
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp?view=diff&rev=543&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r1=542&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp&r2=543
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp?view=diff&rev=543&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r1=542&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r2=543
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
