[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Tue Nov 28 11:16:37 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 - Fix memory leaks in the ODBC provider (merged from branch)
Modified
File: trunk/Providers/GenericRdbms/Src/Fdo/Connection/FdoRdbmsConnection.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Connection/FdoRdbmsConnection.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/Fdo/Connection/FdoRdbmsConnection.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/Fdo/Connection/FdoRdbmsConnection.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.c?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.c&r1=404&p2=trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.c&r2=405
File: trunk/Providers/GenericRdbms/Src/MySQL/Fdo/FdoRdbmsMySqlFilterProcessor.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/Fdo/FdoRdbmsMySqlFilterProcessor.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/MySQL/Fdo/FdoRdbmsMySqlFilterProcessor.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/MySQL/Fdo/FdoRdbmsMySqlFilterProcessor.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.h?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.h&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.h&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcFilterProcessor.cpp&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/connect.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/connect.c?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/connect.c&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/connect.c&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/disconnect.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/disconnect.c?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/disconnect.c&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/disconnect.c&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/proto_p.h&r2=405
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c&r1=404&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/rdbi_init.c&r2=405
File: trunk/Providers/GenericRdbms/Src/Rdbi/term.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Rdbi/term.c?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/Rdbi/term.c&r1=404&p2=trunk/Providers/GenericRdbms/Src/Rdbi/term.c&r2=405
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ov/RdbmsOvClassDefinition.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ov/RdbmsOvClassDefinition.cpp?view=diff&rev=405&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ov/RdbmsOvClassDefinition.cpp&r1=404&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ov/RdbmsOvClassDefinition.cpp&r2=405
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
