[fdo][FDO308][New] WFS: Reconnection to WFS site with different site name resul...
Greg Boone
greg.boone at autodesk.com
Tue Nov 28 17:34:00 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO308
Type
Defect
Artifact ID
FDO308 (WFS: Reconnection to WFS site with different site name results in error)
Reported by
Greg Boone
gregboone (greg.boone at autodesk.com)
New artifact details:
- Description set to new value
1. create a connection to http://cadc-isd-jake.ads.autodesk.com/cgi-bin/mapserv.exe?map=wfs/wfs.map
2. open the connection, and retrive the classes for the first schema.
3. close the connection
4. change the feature server to http://www2.dmsolutions.ca/cgi-bin/mswfs_gmap
5. repeat step 2, retrieve the classes again for the first schema.
result: Classes retrieved from step 2 and 5 are the same.
Expected: They should not be the same as they are from different feature servers.
- Component set to new value
WFS
- Subcomponent set to new value
CONNECTIONS
- Artifact Status set to new value
New
- Target milestone set to new value
3.2.1
- Platform set to new value
All
- Priority set to new value
P2
- Summary set to new value
- Artifact created
- Submission Reviewed set to new value
Yes
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
