[fdo][FDO309][New] Segv in Spatial Context Reader when SDF file contains non-fe...
Brent Robinson brent.robinson at autodesk.com
Wed Nov 29 09:32:37 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO309
Type
 Defect
Artifact ID
 FDO309 (Segv in Spatial Context Reader when SDF file contains non-feature class.)
Reported by
 Brent Robinson
 brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Description set to new value
  Calling the FdoISpatialContextReader::GetDataExtents() function causes a segmentation violation when the SDF file contains a non-feature class.
- Steps to Reproduce set to new value
  - create an SDF file and connect to it
- Add a non-feature class to it
- Do the following:
  FdoPtr<FdoIGetSpatialContexts> gscCmd =
    (FdoIGetSpatialContexts *)
    connection->CreateCommand(
    FdoCommandType_GetSpatialContexts );
  FdoPtr<FdoISpatialContextReader> reader =
     gscCmd->Execute();
  while ( reader->ReadNext() )
    reader->GetExtent();
The above will generate a segv.
- Artifact created
- Summary set to new value
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
