[fdo][FDO170][Modified] Fix memory leaks in the providers
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Nov 29 11:14:38 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170 - Fix memory leaks in the ODBC provider, fixed an unit test (merged from branch)
Modified
File: trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.cpp?view=diff&rev=409&p1=trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.cpp&r1=408&p2=trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.cpp&r2=409
File: trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.h?view=diff&rev=409&p1=trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.h&r1=408&p2=trunk/Providers/GenericRdbms/Src/Fdo/Other/FdoRdbmsSQLDataReader.h&r2=409
File: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp?view=diff&rev=409&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r1=408&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoMultiThreadTest.cpp&r2=409
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
