[fdo][FDO310][New] modifying an existing Value List constraint on a property ra...
    Brent Robinson
    brent.robinson at autodesk.com
    Wed Nov 29 12:49:47 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO310
Type
 Defect
Artifact ID
 FDO310 (modifying an existing Value List constraint on a property raises an unhandled exception)
Reported by
 Brent Robinson
 brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Subcomponent set to new value
  SCHEMA
- Priority set to new value
  P2
- Steps to Reproduce set to new value
  Open an existing schema and modify the List Value Constraint by either adding or removing a value from the FdoPropertyValueConstraintList
Execute the ApplySchema command
RESULT: an unhandled exception is raised
- Artifact Status set to new value
  New
- Artifact created
- Description set to new value
  Modifying an existing Value List constraint on a property raises an unhandled exception
- Summary set to new value
- Version set to new value
  V2
- Platform set to new value
  All
- Component set to new value
  SDF
- Defect Severity set to new value
  High
- Operating system set to new value
  All
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
