[fdo][FDO311][New] Add property to schema causes excessive memory usage
Brent Robinson brent.robinson at autodesk.com
Wed Nov 29 12:55:16 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO311
Type
 Defect
Artifact ID
 FDO311 (Add property to schema causes excessive memory usage)
Reported by
 Brent Robinson
 brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Platform set to new value
  All
- Artifact Status set to new value
  New
- Summary set to new value
- Operating system set to new value
  All
- Priority set to new value
  P1
- Version set to new value
  V2
- Component set to new value
  SDF
- Subcomponent set to new value
  SCHEMA
- Artifact created
- Defect Severity set to new value
  Critical
- Description set to new value
  When a property is added to a feature class, that has a string property and objects, the SDF provider can used up to 1GB of memory. This can lead to crashes if the machine runs out of memory
- Steps to Reproduce set to new value
  - create an SDF file
- Add a schema to it, with one feature class
   - add at least one string property to the
     class.
- Add some objects to the class, via FdoIInsert
- Add a property to the class and do an ApplySchema.
During the last ApplySchema, the SDF provider's memory usage will go up and down sometimes reaching as much as 1GB.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
