[fdo][FDO312][New] SHP/SDF providers: wrong results with ">" filter on strings
    Dan Stoica
    dan.stoica at autodesk.com
    Wed Nov 29 13:49:19 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO312
Type
 Defect
Artifact ID
 FDO312 (SHP/SDF providers: wrong results with ">" filter on strings)
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
  The results of a ">" filter operation using a string property are the same as "<" operation. The results from ">" are wrong.
- Artifact Status set to new value
  New
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
