[fdo][FDO310][Modified] modifying an existing Value List constraint on a property ra...
Brent Robinson brent.robinson at autodesk.com
Wed Nov 29 14:32:18 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO310
Type:
Defect
Artifact ID:
FDO310 (modifying an existing Value List constraint on a property raises an unhandled exception)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO310: merged from 3.2.x branch.
Modified
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=557&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=556&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=557
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp?view=diff&rev=557&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r1=556&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r2=557
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
