[fdo][FDO310][Modified] modifying an existing Value List constraint on a property ra...
Brent Robinson
brent.robinson at autodesk.com
Wed Nov 29 14:59:33 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO310
Type:
Defect
Artifact ID:
FDO310 (modifying an existing Value List constraint on a property raises an unhandled exception)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
Changed FdoPropertyValueConstraintList and FdoPropertyValueConstraintRange to not free the strings returned by FdoDataValue::ToString(). Previously, these strings were freed twice.
New value:
Changed FdoPropertyValueConstraintList and FdoPropertyValueConstraintRange to not free the strings returned by FdoDataValue::ToString(). Previously, these strings ended up being freed twice.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
