[fdo][FDO313][New] Multithreading issues cleanup
Badreddine Karoui
badreddine.karoui at autodesk.com
Wed Nov 29 16:15:50 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO313
Type
Defect
Artifact ID
FDO313 (Multithreading issues cleanup)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact created
- Defect Severity set to new value
Medium
- Summary set to new value
- Platform set to new value
All
- Submission Reviewed set to new value
Yes
- Artifact Status set to new value
New
- Component set to new value
RDBMS
- Priority set to new value
P2
- Description set to new value
Some of the libraries that the RDBMS providers use contain few multithreading issues related to the use of global and static variables. One other issue found is related to the spatial context object holding to a pointer (ByteArray) allocated from a thread specific data. That data may endup getting used by a different thread if the connection holding the spatial context object is shared by multiple threads(a very common occurence)
- Subcomponent set to new value
FEATURE COMMANDS
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
