[fdo][FDO315][New] SHP provider may crash for Featid queries
Dan Stoica dan.stoica at autodesk.com
Wed Nov 29 17:57:55 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO315
Type
 Defect
Artifact ID
 FDO315 (SHP provider may crash for Featid queries)
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Summary set to new value
- Description set to new value
  Apparently the crash is due to attempting to free a vector already freed in ShpFeatIdQueryEvaluator destructor.
- Steps to Reproduce set to new value
  1. Launch MAP 2007
2. Create a SHP connection to the attached parcels.shp (in the zip file) and add the feature class to map
3. Right click on the added Layer and select Query to Filter Data item in the right click pop up menu.
4. In the Feature Source Query dialog, Click Add menu item and select Filter condition in context menu.
5. Type FeatId >= 20 in the Filter condition text filed.
6. Click the OK in the Filter condition dialog and Ok in the Feature Source Query dialog.
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
