[fdo][FDO317][New] SDF Schema edits not commited untill the connection is close...
Badreddine Karoui badreddine.karoui at autodesk.com
Thu Nov 30 13:39:29 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO317
Type
 Defect
Artifact ID
 FDO317 (SDF Schema edits not commited untill the connection is closed)
Reported by
 Badreddine Karoui
 badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Artifact created
- Description set to new value
  The SDF schema modification through the apply schema command needed to be flushed to the file. Otherwise, new connection open for the same SDF file would not see the changes.
- Component set to new value
  SDF
- Defect Severity set to new value
  Medium
- Priority set to new value
  P2
- Submission Reviewed set to new value
  Yes
- Subcomponent set to new value
  FEATURE COMMANDS
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
