[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica dan.stoica at autodesk.com
Wed Oct 4 12:52:18 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO170
Merged rev.222 from trunk to branch
Modified
File: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/Geometry/Fgf/AllGeometry_c.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/Geometry/Fgf/AllGeometry_c.cpp?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/Geometry/Fgf/AllGeometry_c.cpp&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/Geometry/Fgf/AllGeometry_c.cpp&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/geom.c https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/geom.c?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/geom.c&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/geom.c&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/structs.h https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/structs.h?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/structs.h&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/ODBCDriver/structs.h&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.cpp&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSelectTest.h&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/GeometryTests.cpp&r2=223
File: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp?view=diff&rev=223&p1=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r1=222&p2=branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r2=223
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
