[fdo][FDO199][New] FDO: Update Spatial API to include class FdoSpatialGeometryC...
Greg Boone greg.boone at autodesk.com
Wed Oct 4 14:20:44 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO199
Type
 Task
Artifact ID
 FDO199 (FDO: Update Spatial API to include class FdoSpatialGeometryConverter)
Reported by
 Greg Boone
 gregboone (greg.boone at autodesk.com)
New artifact details:
- Need By Date set to new value
  2006-10-04
- Artifact created
- Summary set to new value
- Task Priority set to new value
  Medium
- Target milestone set to new value
  3.2.0
- Planned Completion Date set to new value
  2006-10-04
- Priority set to new value
  P2
- Artifact Status set to new value
  New
- Description set to new value
  This submission assists in fixing Autodesk defect 819059.02 -- When DEM assigned a coordinate system it does not load.
This change places a workaround in the FDO API to compensate for the ATIL API change that resulted in DEM images being returned with a resolution and insertion point in ArcSeconds rather than degrees. In this submission, The Raster provider will evaluate the raster image loaded from ATIL to determine if the resolution units are in ArcSeconds or Radians. If so, appropriate conversions will be made to ensure that the user is returned a raster image in degrees.
- Planned Start Date set to new value
  2006-10-04
- Actual Completion Date set to new value
  2006-10-04
- Actual Start Date set to new value
  2006-10-04
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
