[fdo][FDO200][New] SHP provider fails to read PolygonZShape
Dan Stoica dan.stoica at autodesk.com
Wed Oct 4 14:34:42 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO200
Type
 Defect
Artifact ID
 FDO200 (SHP provider fails to read PolygonZShape)
Reported by
 Dan Stoica
 danstoica (dan.stoica at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Artifact created
- Description set to new value
  An exception is being thrown under the SHPProvider's PolygonZShape::GetGeometry () call. Three other approaches that use FDO (GeoBrowser, ESRI and _mapimport ) all read the shp file without a problem.
- Summary set to new value
- Steps to Reproduce set to new value
  Any SHP file that contains a XYZ polygon not matching the Z ordinate will fail to load.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
