[fdo][FDO198][Modified] DescribeSchema slow after Oracle Cache flush performed
Brent Robinson brent.robinson at autodesk.com
Thu Oct 5 18:59:38 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO198
Type:
Defect
Artifact ID:
FDO198 (DescribeSchema slow after Oracle Cache flush performed)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO198: skip bulk load of unique and check constraints, unless an ApplySchema or DescribeSchema is being performed. Skip bulk loading of corresponding tables for the F_MetaClass schema.
Reviewed by Badreddine Karoui
Modified
File: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/Schema.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/Schema.h?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/Schema.h&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Lp/Schema.h&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r2=428
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp?view=diff&rev=428&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp&r1=427&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/SchemaManager.cpp&r2=428
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
