[fdo][FDO208][New] FDO RDBMS Schema Single class load when used by a feature co...
Badreddine Karoui
badreddine.karoui at autodesk.com
Fri Oct 6 15:53:33 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO208
Type
Defect
Artifact ID
FDO208 (FDO RDBMS Schema Single class load when used by a feature command)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Summary set to new value
- Priority set to new value
P5
- Description set to new value
The execution of a feature command triggers the load of the whole schema. In the case of large number of classes, this adds a significant time to the command ececution. With this change only the classes required by the execution of a feature command are loaded.
- Artifact Status set to new value
New
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
