[fdo][FDO211][New] SDF insert new feature may corrupt the RTree
Badreddine Karoui badreddine.karoui at autodesk.com
Tue Oct 10 15:17:09 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO211
Type
 Defect
Artifact ID
 FDO211 (SDF insert new feature may corrupt the RTree)
Reported by
 Badreddine Karoui
 badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
  This is the steps to reproduce this issue:
- Create a connection1
- create connection2
- Use connection2 to insert few features(less than 50).
- close connection2
- create an insert command using connection1
- insert a single feature
- close connection1
The Rtree may no have all the features. Basically if the single last feature is added to the root node, then only that feature will end up in the root node.
- Artifact created
- Priority set to new value
  P2
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
