[fdo][FDO208][Modified] FDO RDBMS Schema Single class load when used by a feature co...
Badreddine Karoui badreddine.karoui at autodesk.com
Tue Oct 10 17:08:26 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO208
Type:
Defect
Artifact ID:
FDO208 (FDO RDBMS Schema Single class load when used by a feature command)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO208
Modified
File: branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.cpp?view=diff&rev=244&p1=branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.cpp&r1=243&p2=branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.cpp&r2=244
File: branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.h https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.h?view=diff&rev=244&p1=branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.h&r1=243&p2=branches/3.2.x/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Ph/Mgr.h&r2=244
File: branches/3.2.x/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/ClassReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/ClassReader.cpp?view=diff&rev=244&p1=branches/3.2.x/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/ClassReader.cpp&r1=243&p2=branches/3.2.x/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/ClassReader.cpp&r2=244
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
