[fdo][FDO205][Modified] Update "Bad parameter to method" exception in FDO
Thomas Knoell
thomas.knoell at autodesk.com
Wed Oct 11 10:16:46 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO205
Type:
Defect
Artifact ID:
FDO205 (Update "Bad parameter to method" exception in FDO)
Modified by:
Thomas Knoell
thomasknoell (thomas.knoell at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO205 (trunk)
Modified
File: trunk/Fdo/UnitTest/GeometryTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/GeometryTest.cpp?view=diff&rev=447&p1=trunk/Fdo/UnitTest/GeometryTest.cpp&r1=446&p2=trunk/Fdo/UnitTest/GeometryTest.cpp&r2=447
File: trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h&r1=446&p2=trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h&r2=447
File: trunk/Fdo/Unmanaged/Inc/Common/Ptr.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Inc/Common/Ptr.h?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Inc/Common/Ptr.h&r1=446&p2=trunk/Fdo/Unmanaged/Inc/Common/Ptr.h&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/DirectPositionImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/DirectPositionImpl.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/DirectPositionImpl.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/DirectPositionImpl.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/EnvelopeImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/EnvelopeImpl.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/EnvelopeImpl.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/EnvelopeImpl.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CircularArcSegment.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CircularArcSegment.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CircularArcSegment.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CircularArcSegment.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurvePolygon.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurvePolygon.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurvePolygon.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurvePolygon.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurveString.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurveString.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurveString.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/CurveString.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryFactory.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/GeometryImpl.h&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineString.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineStringSegment.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineStringSegment.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineStringSegment.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LineStringSegment.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LinearRing.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LinearRing.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LinearRing.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/LinearRing.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurvePolygon.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurvePolygon.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurvePolygon.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurvePolygon.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurveString.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurveString.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurveString.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiCurveString.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiGeometry.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiGeometry.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiGeometry.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiGeometry.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiLineString.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiLineString.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiLineString.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiLineString.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPoint.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPoint.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPoint.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPoint.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPolygon.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPolygon.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPolygon.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/MultiPolygon.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Point.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Point.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Point.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Point.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Polygon.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Polygon.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Polygon.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Polygon.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Pool.h&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Ring.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Ring.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Ring.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Ring.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/Fgf/Util.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/GeometryFactoryAbstract.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/GeometryFactoryAbstract.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/GeometryFactoryAbstract.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/GeometryFactoryAbstract.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Geometry/GeometryUtility.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Geometry/GeometryUtility.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Geometry/GeometryUtility.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Geometry/GeometryUtility.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r1=446&p2=trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc&r2=447
File: trunk/Fdo/Unmanaged/Src/Spatial/MathUtility.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Spatial/MathUtility.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Spatial/MathUtility.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Spatial/MathUtility.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Spatial/SpatialGridTransform.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Spatial/SpatialGridTransform.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Spatial/SpatialGridTransform.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Spatial/SpatialGridTransform.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtility.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtility.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtility.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtility.cpp&r2=447
File: trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtilityCircularArc.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtilityCircularArc.cpp?view=diff&rev=447&p1=trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtilityCircularArc.cpp&r1=446&p2=trunk/Fdo/Unmanaged/Src/Spatial/SpatialUtilityCircularArc.cpp&r2=447
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
