[fdo][FDO212][New] Fixed FdoMySqlImportExportTest file comparison errors
Brent Robinson
brent.robinson at autodesk.com
Thu Oct 12 10:06:57 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO212
Type
Defect
Artifact ID
FDO212 (Fixed FdoMySqlImportExportTest file comparison errors)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Defect Severity set to new value
Low
- Summary set to new value
- Target milestone set to new value
3.2.1
- Priority set to new value
P4
- Component set to new value
RDBMS
- Subcomponent set to new value
UNIT TESTS
- Platform set to new value
PC
- Artifact created
- Steps to Reproduce set to new value
- run MySqlImportExportTest.test2_3_4 on Windows (Linux is ok).
- get exception indicating that impexp2a.xml is different from the master (expected results) file.
- Description set to new value
This artifact fixes ImportExportTest suite to address some output/master file comparison differences that are happening in G022. The differences are due to different ordering of the file contents, rather than actual differences.
This is a defect in the unit test, rather than in the RDBMS Providers themselves.
- Version set to new value
V2
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
