[fdo][FDO214][Modified] Schema Reverse-Engineering fails if foreign key named the sa...
Brent Robinson brent.robinson at autodesk.com
Fri Oct 13 14:35:11 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO214
Type:
Defect
Artifact ID:
FDO214 (Schema Reverse-Engineering fails if foreign key named the same as column.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO214
Modified
File: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h?view=diff&rev=453&p1=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h&r1=452&p2=branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h&r2=453
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp?view=diff&rev=453&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r1=452&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r2=453
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
