[fdo][FDO214][Modified] Schema Reverse-Engineering fails if foreign key named the sa...
Brent Robinson brent.robinson at autodesk.com
Fri Oct 13 14:45:14 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO214
Type:
Defect
Artifact ID:
FDO214 (Schema Reverse-Engineering fails if foreign key named the same as column.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO214: Merged from 3.2.x
Modified
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp?view=diff&rev=256&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp&r1=255&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp&r2=256
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h?view=diff&rev=256&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h&r1=255&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h&r2=256
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp?view=diff&rev=256&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r1=255&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.cpp&r2=256
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.h?view=diff&rev=256&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.h&r1=255&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlSchemaMgrTests.h&r2=256
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
