[fdo][FDO216][New] Cannot set Data Property constraint to null, through managed...
Brent Robinson
brent.robinson at autodesk.com
Mon Oct 16 09:56:19 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO216
Type
Defect
Artifact ID
FDO216 (Cannot set Data Property constraint to null, through managed FDO API)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Defect Severity set to new value
High
- Steps to Reproduce set to new value
The following Managed API code reproduces the problem:
DataPropertyDefinition pProp = new
DataPropertyDefinition("Volume", "");
pProp.ValueConstraint = null;
- Component set to new value
- Description set to new value
Using the managed FDO API, to set a data property constraint to null, generated the following error:
"Object reference not set to an instance of an object."
- Subcomponent set to new value
SCHEMA
- Summary set to new value
- Artifact created
- Version set to new value
V2
- Platform set to new value
All
- Priority set to new value
P2
- Operating system set to new value
All
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
