[fdo][FDO225][Modified] MySQL: Can't create foreign schema using schema level overri...
Brent Robinson brent.robinson at autodesk.com
Mon Oct 23 16:07:46 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO225
Type:
Defect
Artifact ID:
FDO225 (MySQL: Can't create foreign schema using schema level overrides)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO225: Merged from 3.2.x branch
Modified
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/ClassDefinition.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/ClassDefinition.cpp?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/ClassDefinition.cpp&r1=272&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/ClassDefinition.cpp&r2=273
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/Schema.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/Schema.cpp?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/Schema.cpp&r1=272&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/Schema.cpp&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalSorter.xslt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoApplySchemaTest.cpp&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt&r2=273
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt?view=diff&rev=273&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt&r1=272&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt&r2=273
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
