[fdo][FDO227][New] ODBC Oracle: cannot insert with a FdoDataType_DateTime value
Barbara Zoladek barbara.zoladek at autodesk.com
Tue Oct 24 15:34:03 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO227
Type
 Defect
Artifact ID
 FDO227 (ODBC Oracle: cannot insert with a FdoDataType_DateTime value)
Reported by
 Barbara Zoladek
 barbarazoladek (barbara.zoladek at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
  Oracle - Constraints cannot insert with a FdoDataType_DateTime value if the FdoDataType_DateTime is part of unique constraint definition
- Defect Severity set to new value
  Medium
- Summary set to new value
- Artifact Status set to new value
  New
- Steps to Reproduce set to new value
  Create a FeatureClass with a unique constraint on a FdoDataType_DateTime
Insert a feature with a value for the FdoDataType_DateTime property
EXPECTED RESULT: the feature is inserted
ACTUAL RESULT:
FdoCommandException(): ORA-01861: LITERAL DOES NOT MATCH FORMAT STRING
ROW IS : '40', '128', '2006-01-31-10-30-30', '', '', '', '', '', '', '', 24, 0.
ISSUING ROLLBACK TO RECOVER FROM TRANSACTION FAILURE
ROLLBACK COMPLETE
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
