[fdo][FDO232][New] Errors accessing datastores created by older versions of FDO...
Brent Robinson
brent.robinson at autodesk.com
Thu Oct 26 13:38:44 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO232
Type
Defect
Artifact ID
FDO232 (Errors accessing datastores created by older versions of FDO.)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Subcomponent set to new value
SCHEMA
- Artifact created
- Component set to new value
RDBMS
- Artifact Status set to new value
New
- Version set to new value
V2
- Description set to new value
It is not possible to execute a DescribeSchema a pre-FDO 3.1 Oracle datastore via the 3.2 Oracle Provider.
Also, feature commands fail when run against a MySQL datastore, with metaschema,created by FDO 3.1.
- Steps to Reproduce set to new value
- execute an FdoIDescribeSchema on a pre-FDO 3.1 Oracle datastore (e.g. a datastore created by MAP 2006).
- get the following:
ORA-01789: query block has incorrect number of result columns
- execute an FdoIInsert command against a MySQL datastore created by FDO 3.1
The provided input is invalid for the current mapping process.
- Target milestone set to new value
3.2.1
- Priority set to new value
P1
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
