[fdo][FDO232][Modified] Errors accessing datastores created by older versions of FDO...
Brent Robinson brent.robinson at autodesk.com
Fri Oct 27 09:26:13 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO232
Type:
Defect
Artifact ID:
FDO232 (Errors accessing datastores created by older versions of FDO.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO232:
    - fixed problems accessing older datastores
    - enabled describe of specific geometrytypes.
    - enabled update of specific GeometryTypes
Modified
File: branches/3.2.x/Utilities/Common/Inc/FdoCommonGeometryUtil.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/Inc/FdoCommonGeometryUtil.h?view=diff&rev=471&p1=branches/3.2.x/Utilities/Common/Inc/FdoCommonGeometryUtil.h&r1=470&p2=branches/3.2.x/Utilities/Common/Inc/FdoCommonGeometryUtil.h&r2=471
File: branches/3.2.x/Utilities/Common/Src/FdoCommonGeometryUtil.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/Src/FdoCommonGeometryUtil.cpp?view=diff&rev=471&p1=branches/3.2.x/Utilities/Common/Src/FdoCommonGeometryUtil.cpp&r1=470&p2=branches/3.2.x/Utilities/Common/Src/FdoCommonGeometryUtil.cpp&r2=471
File: branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc?view=diff&rev=471&p1=branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc&r1=470&p2=branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc&r2=471
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp?view=diff&rev=471&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp&r1=470&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp&r2=471
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp?view=diff&rev=471&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp&r1=470&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp&r2=471
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp?view=diff&rev=471&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r1=470&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r2=471
File: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp?view=diff&rev=471&p1=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp&r1=470&p2=branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp&r2=471
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
