[fdo][FDO232][Modified] Errors accessing datastores created by older versions of FDO...
Brent Robinson
brent.robinson at autodesk.com
Fri Oct 27 09:49:57 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO232
Type:
Defect
Artifact ID:
FDO232 (Errors accessing datastores created by older versions of FDO.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO232: merged from 3.2.x branch
Modified
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp?view=diff&rev=473&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp&r1=472&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/GeometricPropertyDefinition.cpp&r2=473
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
