[fdo][FDO232][Modified] Errors accessing datastores created by older versions of FDO...
Brent Robinson
brent.robinson at autodesk.com
Fri Oct 27 09:55:04 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO232
Type:
Defect
Artifact ID:
FDO232 (Errors accessing datastores created by older versions of FDO.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO232: merged from 3.2.x branch
Modified
File: trunk/Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsDescribeSchemaCommand.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsDescribeSchemaCommand.cpp?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsDescribeSchemaCommand.cpp&r1=287&p2=trunk/Providers/GenericRdbms/Src/Fdo/Schema/FdoRdbmsDescribeSchemaCommand.cpp&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign3_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign3_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign3_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides1_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides2_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_def1_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt&r2=288
File: trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt?view=diff&rev=288&p1=trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt&r1=287&p2=trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt&r2=288
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
