[fdo][FDO233][New] SelectAggregate using GroupBy and OrderBy fails
Barbara Zoladek
barbara.zoladek at autodesk.com
Fri Oct 27 15:07:18 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO233
Type
Defect
Artifact ID
FDO233 (SelectAggregate using GroupBy and OrderBy fails)
Reported by
Barbara Zoladek
barbarazoladek (barbara.zoladek at autodesk.com)
New artifact details:
- Platform set to new value
All
- Artifact Status set to new value
New
- Component set to new value
RDBMS
- Subcomponent set to new value
FEATURE COMMANDS
- Summary set to new value
- Description set to new value
It appears a SelectAggregate that includes a GroupBy and an OrderBy fails with FDO error "property" already in the named collection. This is a regression from FDO 68 in which this worked. This also worked in the release of Tux using FDO 50. If the OrderBy is removed then the SelectAggregate executes.
- Artifact created
- Defect Severity set to new value
Medium
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
