[fdo][FDO241][New] Second constraint lost when deserializing class with 2 uniqu...
Brent Robinson
brent.robinson at autodesk.com
Mon Oct 30 11:21:01 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO241
Type
Defect
Artifact ID
FDO241 (Second constraint lost when deserializing class with 2 unique constraints from XML.)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Summary set to new value
- Operating system set to new value
All
- Artifact created
- Platform set to new value
All
- Priority set to new value
P2
- Defect Severity set to new value
High
- Version set to new value
V2
- Component set to new value
- Artifact Status set to new value
New
- Steps to Reproduce set to new value
- start with a XML Schema file with a class that has 2 unique constraints
- deserialize the file using FdoFeatureSchemaCollection::ReadXml
- Open a connection with the Oracle Provider and apply the feature schema that was read to the opened datastore.
Only the second constraint makes it into the datastore
- Description set to new value
When a class with 2 unique constraints is read from XML, the first constraint becomes empty (no properties).
This is a regression from some fdo\Schema\MergeContext.cpp changes made in August 2006.
- Subcomponent set to new value
XML IN/OUT
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
