[fdo][FDO242][New] Errors due to wrong MySQL version not reported
Brent Robinson
brent.robinson at autodesk.com
Mon Oct 30 11:27:04 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO242
Type
Defect
Artifact ID
FDO242 (Errors due to wrong MySQL version not reported)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Subcomponent set to new value
CONNECTIONS
- Artifact Status set to new value
New
- Description set to new value
The MySQL provider does not support MySQL 4 server or client. However, when the MySQL provider accesses a version 5 MySQL server via version 4 client, the generated exception message is "RDBMS:".
The following message is written to stdout:
[2036] Using unsupported buffer type: 0 (parameter: 1)
This message should also be included in the exception message. Although cryptic, it provides a clue as to what the problem is.
- Component set to new value
RDBMS
- Steps to Reproduce set to new value
- installed MySQL 4.1 on same machine as FDO.
- Opened an FDO connection to a MySQL 5 database on another machine,
- Executed a ListDatastores command. Got the following exception message:
RDBMS:
- Priority set to new value
P2
- Summary set to new value
- Operating system set to new value
All
- Artifact created
- Platform set to new value
All
- Version set to new value
V2
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
