[fdo][FDO236][Modified] Support a Flush function by the FDO connection
Badreddine Karoui badreddine.karoui at autodesk.com
Tue Oct 31 15:43:22 EST 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO236
Type:
Enhancement
Artifact ID:
FDO236 (Support a Flush function by the FDO connection)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO236
Modified
File: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Connection.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.cpp?view=diff&rev=481&p1=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.cpp&r1=480&p2=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.cpp&r2=481
File: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Connection.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.h?view=diff&rev=481&p1=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.h&r1=480&p2=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/Connection.h&r2=481
File: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/ConnectionCapabilities.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.cpp?view=diff&rev=481&p1=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.cpp&r1=480&p2=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.cpp&r2=481
File: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/ConnectionCapabilities.h https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.h?view=diff&rev=481&p1=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.h&r1=480&p2=branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup%20Files/Wizard/Templates/1033/ConnectionCapabilities.h&r2=481
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
