[fdo][FDO155][New] SDF: Returned geometry from the SpatialExtents function is a...
Greg Boone
greg.boone at autodesk.com
Wed Sep 6 11:27:08 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO155
Type
Defect
Artifact ID
FDO155 (SDF: Returned geometry from the SpatialExtents function is a LineString instead of a Polygon)
Reported by
Greg Boone
gregboone (greg.boone at autodesk.com)
New artifact details:
- Priority set to new value
P2
- Related Artifacts set to new value
Clarify Defect 804766
- Artifact Status set to new value
New
- Description set to new value
1/ Insert one feature in the datastore with this geometry, LINESTRING XYZ (10 10 0, 20 20 0, 30 40 0). Make sure it is the only feature in that class.
2/ Execute a SpatialExtents on that class.
Result: The returned geometry is LINESTRING XYZ (10 10 0, 30 40 0)
Expected Result: POLYGON ((10 10, 30 10, 30 40, 10 40, 10 10)) as the Oracle provider returns in this case.
- Target milestone set to new value
3.2.0
- Component set to new value
SDF
- Defect Severity set to new value
High
- Platform set to new value
All
- Artifact created
- Operating system set to new value
All
- Subcomponent set to new value
FEATURE COMMANDS
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
