[fdo][FDO156][New] SDF: Roll back the 3.2 schema version and generate SDF files...
Badreddine Karoui
badreddine.karoui at autodesk.com
Wed Sep 6 12:03:00 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO156
Type
Defect
Artifact ID
FDO156 (SDF: Roll back the 3.2 schema version and generate SDF files readable by older SDF providers)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Priority set to new value
P2
- Target milestone set to new value
3.2.0
- Platform set to new value
All
- Component set to new value
SDF
- Summary set to new value
- Subcomponent set to new value
SCHEMA
- Description set to new value
The change described by atifact FDO103 introduced a new SDF schema version. As a result older version of the SDF provider will not be able to read new SDF file created by the new version. This change rollback the version change and provides a different solution to the issue addresses by FDO103: problems with classes with non-ASCII7 names.
The solution is to provide mappings for both the old MBCS based table names and the new more robust UTF8 based table names.
- Operating system set to new value
All
- Related Artifacts set to new value
FDO103
- Defect Severity set to new value
Medium
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
