[fdo][FDO160][New] Fixed Defect 823645 - SDF doesn't accept "false" (lower case...
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Sep 6 19:41:46 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO160
Type
Defect
Artifact ID
FDO160 (Fixed Defect 823645 - SDF doesn't accept "false" (lower case))
Reported by
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
New artifact details:
- Summary set to new value
- Description set to new value
Fixed connection property by adding a new property (IsSensitiveCase).
This property will decide if one enumerable property is sensitive case or not.
- Artifact Status set to new value
New
- Defect Severity set to new value
High
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
