[fdo][FDO155][Modified] SDF: Returned geometry from the SpatialExtents function is a...
Greg Boone
greg.boone at autodesk.com
Thu Sep 7 20:09:11 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO155
Type:
Defect
Artifact ID:
FDO155 (SDF: Returned geometry from the SpatialExtents function is a LineString instead of a Polygon)
Modified by:
Greg Boone
gregboone (greg.boone at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO155: Returned geometry from the SpatialExtents function is a LineString instead of a Polygon
Modified
File: trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp?view=diff&rev=344&p1=trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp&r1=343&p2=trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp&r2=344
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
