[fdo][FDO155][Modified] SDF/SHP: Returned geometry from the SpatialExtents function ...
Greg Boone greg.boone at autodesk.com
Mon Sep 11 10:14:35 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO155
Type:
Defect
Artifact ID:
FDO155 (SDF/SHP: Returned geometry from the SpatialExtents function is a LineString instead of a Polygon)
Modified by:
Greg Boone
gregboone (greg.boone at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO155: Fix Linux crash uncovered by addition of UnitTest
Modified
File: trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp?view=diff&rev=347&p1=trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp&r1=346&p2=trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp&r2=347
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
