[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica
dan.stoica at autodesk.com
Wed Sep 13 17:10:19 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170
Modified
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/SchemaReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/SchemaReader.cpp?view=diff&rev=194&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/SchemaReader.cpp&r1=193&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Cfg/SchemaReader.cpp&r2=194
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp?view=diff&rev=194&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp&r1=193&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/FieldArray.cpp&r2=194
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp?view=diff&rev=194&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp&r1=193&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Rd/QueryReader.cpp&r2=194
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
