[fdo][FDO174][Modified] SDF delete schema support
Badreddine Karoui badreddine.karoui at autodesk.com
Thu Sep 14 13:52:33 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO174
Type:
Task
Artifact ID:
FDO174 (SDF delete schema support)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
This is required to add the SDF schema delete support.
It was originally though that deleting the schema is equivalent to deleting the file itself. However, adding schema delete enable the SDF provider to supoprt this specific FDO API.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
