[fdo][FDO174][Modified] SDF delete schema support
Badreddine Karoui badreddine.karoui at autodesk.com
Thu Sep 14 15:45:25 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO174
Type:
Task
Artifact ID:
FDO174 (SDF delete schema support)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO174
Modified
File: trunk/Providers/SDF/Src/Provider/SchemaDb.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SchemaDb.cpp?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SchemaDb.cpp&r1=99&p2=trunk/Providers/SDF/Src/Provider/SchemaDb.cpp&r2=100
File: trunk/Providers/SDF/Src/Provider/SchemaDb.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SchemaDb.h?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SchemaDb.h&r1=99&p2=trunk/Providers/SDF/Src/Provider/SchemaDb.h&r2=100
File: trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp&r1=99&p2=trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp&r2=100
File: trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.cpp?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.cpp&r1=99&p2=trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.cpp&r2=100
File: trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.h?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.h&r1=99&p2=trunk/Providers/SDF/Src/Provider/SdfSchemaMergeContext.h&r2=100
File: trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp?view=diff&rev=100&p1=trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp&r1=99&p2=trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp&r2=100
File: trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp?view=diff&rev=100&p1=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp&r1=99&p2=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp&r2=100
File: trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h?view=diff&rev=100&p1=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h&r1=99&p2=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h&r2=100
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_err2_master.txt https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_err2_master.txt?view=diff&rev=100&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_err2_master.txt&r1=99&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_err2_master.txt&r2=100
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml?view=diff&rev=100&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml&r1=99&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml&r2=100
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml?view=diff&rev=100&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml&r1=99&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml&r2=100
File: trunk/Providers/SDF/TestData/PARCEL_linuxtest.SDX https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/TestData/PARCEL_linuxtest.SDX?view=diff&rev=100&p1=trunk/Providers/SDF/TestData/PARCEL_linuxtest.SDX&r1=99&p2=trunk/Providers/SDF/TestData/PARCEL_linuxtest.SDX&r2=100
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
