[fdo][FDO173][Modified] New Capability Support for GenericRDBMS, WFS, WMS
Thomas Knoell thomas.knoell at autodesk.com
Thu Sep 14 19:32:42 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO173
Type:
Enhancement
Artifact ID:
FDO173 (New Capability Support for GenericRDBMS, WFS, WMS)
Modified by:
Thomas Knoell
thomasknoell (thomas.knoell at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO173 - Updating unit test master files.
Modified
File: trunk/Fdo/UnitTest/SchemaTest.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/SchemaTest.cpp?view=diff&rev=362&p1=trunk/Fdo/UnitTest/SchemaTest.cpp&r1=361&p2=trunk/Fdo/UnitTest/SchemaTest.cpp&r2=362
File: trunk/Fdo/UnitTest/schema_all1_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all1_master.txt?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_all1_master.txt&r1=361&p2=trunk/Fdo/UnitTest/schema_all1_master.txt&r2=362
File: trunk/Fdo/UnitTest/schema_all_v2.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all_v2.xml?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_all_v2.xml&r1=361&p2=trunk/Fdo/UnitTest/schema_all_v2.xml&r2=362
File: trunk/Fdo/UnitTest/schema_all_v2_out_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_all_v2_out_master.txt?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_all_v2_out_master.txt&r1=361&p2=trunk/Fdo/UnitTest/schema_all_v2_out_master.txt&r2=362
File: trunk/Fdo/UnitTest/schema_ext_a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_ext_a_master.txt?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_ext_a_master.txt&r1=361&p2=trunk/Fdo/UnitTest/schema_ext_a_master.txt&r2=362
File: trunk/Fdo/UnitTest/schema_merge1a.xml https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge1a.xml?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_merge1a.xml&r1=361&p2=trunk/Fdo/UnitTest/schema_merge1a.xml&r2=362
File: trunk/Fdo/UnitTest/schema_merge2a_master.txt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/UnitTest/schema_merge2a_master.txt?view=diff&rev=362&p1=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r1=361&p2=trunk/Fdo/UnitTest/schema_merge2a_master.txt&r2=362
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
