[fdo][FDO175][New] SDF command capability and concurency access fixes
Badreddine Karoui
badreddine.karoui at autodesk.com
Fri Sep 15 15:05:11 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO175
Type
Defect
Artifact ID
FDO175 (SDF command capability and concurency access fixes)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Version set to new value
V3
- Description set to new value
The new extended select command is not added to the command capability and part of a fix was not propagated to the open source trunc.
- Summary set to new value
- Platform set to new value
All
- Artifact created
- Defect Severity set to new value
Medium
- Priority set to new value
P2
- Component set to new value
SDF
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
