[fdo][FDO176][Modified] Fix 775090.01 Spatial Contexts with large extent/small toler...
Gavin Cramer
gavin.cramer at autodesk.com
Fri Sep 15 16:16:07 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO176
Type:
Task
Artifact ID:
FDO176 (Fix 775090.01 Spatial Contexts with large extent/small tolerance)
Modified by:
Gavin Cramer
gavincramer (gavin.cramer at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO176
Modified
File: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp?view=diff&rev=197&p1=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r1=196&p2=trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSqlCmdTest.cpp&r2=197
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
