[fdo][FDO177][New] ODBC: Unit tests for feature commands
Gavin Cramer gavin.cramer at autodesk.com
Fri Sep 15 16:29:00 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO177
Type
 Task
Artifact ID
 FDO177 (ODBC: Unit tests for feature commands)
Reported by
 Gavin Cramer
 gavincramer (gavin.cramer at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Task Priority set to new value
  Medium
- Artifact created
- Description set to new value
  Refactor and augment unit tests for Select, Insert, Update and Delete commands.  Limited changes for SelectAggregates too.  This is to expand ODBC Provider testing for Oracle, SQL Server, MySQL and dBASE databases.
Two fixes for NULL checks were made to GenericRdbms.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
