[fdo][FDO182][Modified] Fixed defect 829370 GML schema not supporting elements with ...
Romica Dascalescu
romica.dascalescu at autodesk.com
Wed Sep 20 12:21:29 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO182
Type:
Defect
Artifact ID:
FDO182 (Fixed defect 829370 GML schema not supporting elements with complex types which contains a reference)
Modified by:
Romica Dascalescu
romicadascalescu (romica.dascalescu at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO182
Modified
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h?view=diff&rev=376&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r1=375&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.h&r2=376
File: trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt?view=diff&rev=376&p1=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r1=375&p2=trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromExternal.xslt&r2=376
File: trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp?view=diff&rev=376&p1=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp&r1=375&p2=trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp&r2=376
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
