[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica
dan.stoica at autodesk.com
Fri Sep 22 15:59:39 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170
Modified
File: trunk/Providers/GenericRdbms/Src/Fdo/DataStore/FdoRdbmsGetDataStores.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/DataStore/FdoRdbmsGetDataStores.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/Fdo/DataStore/FdoRdbmsGetDataStores.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/Fdo/DataStore/FdoRdbmsGetDataStores.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsDeleteCommand.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsDeleteCommand.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsDeleteCommand.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsDeleteCommand.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/Fdo/Lock/LockUtility.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/Fdo/Lock/LockUtility.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/Fdo/Lock/LockUtility.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/Fdo/Lock/LockUtility.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/ColumnReader.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/DbObjectReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/DbObjectReader.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/DbObjectReader.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/DbObjectReader.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/OwnerReader.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/OwnerReader.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/OwnerReader.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/OwnerReader.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.cpp&r2=208
File: trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c&r1=207&p2=trunk/Providers/GenericRdbms/Src/ODBCDriver/geom.c&r2=208
File: trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/CommandWriter.cpp https://fdordbms.osgeo.org/source/browse/fdordbms/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/CommandWriter.cpp?view=diff&rev=208&p1=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/CommandWriter.cpp&r1=207&p2=trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/CommandWriter.cpp&r2=208
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
